My phone is stuck on the startup screen. Won't turn off. What do I do?
Phones froze on startup screen!
Esta é uma boa pergunta?
@donnienewton77 pull the battery and wait some time, then reinsert and double check LG K30 Battery Replacement
Esta resposta foi útil?
When your phone is stuck at the logo screen, it is usually a sign that the phone is having problems loading the software from the built-in flash memory. If a simple restart does not fix your issue, you may need to wipe the device. Here are some instructions on how to complete that process (NOTE: this will erase all personal data from the phone).
If you are still having problems with the phone not loading, then it is a hardware problem and a logic board replacement is the next step.
My phone is stuck at the circle lock screen what should i do
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 921
