Ir para o conteúdo principal
LG K30 Battery Replacement
O que você precisa
  1. LG K30 Battery Replacement, Battery: passo 1, imagem 1 %32 LG K30 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
    Pergunte ao FixBot
    Comentar
  2. LG K30 Battery Replacement: passo 2, imagem 1 %32
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    Pergunte ao FixBot
    Comentar
  3. LG K30 Battery Replacement: passo 3, imagem 1 %32
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
    Pergunte ao FixBot
    Comentar
  4. LG K30 Battery Replacement: passo 4, imagem 1 %32
    • Use the flat end of a spudger to detach the battery connector from the logic board.
    Pergunte ao FixBot
    Comentar
  5. LG K30 Battery Replacement: passo 5, imagem 1 %32 LG K30 Battery Replacement: passo 5, imagem 2 %32
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
2Comentários do guia
There's no description of removing the display or supporting it. Why is an LG K30 screen with frame required?
P Schmied - Responder Compartilhar
thank you it really meant a lot
Albert E - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 62
Ao todo: 14,165
