Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Flash, front and rear camera all not working
Hey guys, pretty new to this. Recently repaired the WiFi and Bluetooth antenna on my iPhone 5s. When I’ve put it back together, the front and back camera are both black and the flash won’t work at all.
any one got any ideas on this?
Thank you.
gary
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The Front Camera and Flash will not work if the Rear Camera is defective/damaged/disconnected so focus your efforts on the rear camera. Start by verifying if it is properly connected. You can also check the condition of the connector (flex and board) as well as the general condition of the flex cable itself and the logic board. The flex is delicate and even the tiniest tear can cause issues. Likewise for the logic board as there are tiny components all around the connector and damaging or dislodging components can happen.
If everything looks okay, you could try to disconnect the FCAM & Flash and see if the Rear camera works by itself. If it doesn’t, then consider replacing the camera.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Gary Freeman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 31
