Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Perguntas Visualizar todos
Which MacBook do I have?
Mis for musical, your hidden talent!
Ais for activities, for you have many.
Cis for congenial, your pleasing way.
Kis for kindle, the warmth in others.
Eis for excellence, your passion, your drive.
Iis for inventor, how many things will you create?
Sis for sweet, your pleasing way.
His for honor, your most valuable possession.
Ais for authentic, be real
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Shouldn't the model number be written on the bottom cover of your mac?
id your mac
Esta resposta foi útil?
Pontuação 4
1 comentário:
If all you care about is what model it is, go through the following list:
Is it white or aluminum? If aluminum, you have A1278.
If white, does it have a trackpad button along with the trackpad, or does the entire trackpad physically click as the trackpad button? If it has a trackpad button, it is A1181.
If the entire trackpad clicks as the trackpad button, it is A1342.
If you need further information, follow s2c97's link for the most specific and accurate info!
por
Goto system profiler. Print All info, go to Apple menu -> About This Mac, write it and figure out which Macbook do you have.
Pontuação 0
Take the battery out and look on the side wall of the battery compartment.
Pontuação 0
Adicionar a sua resposta
Mackeisha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 7,906
