Ir para o conteúdo principal
Um aspirador de pó vertical potente e sem saco, parte da série DC lançada em 2009. Seu número de modelo é 15804-01.
How do I remove the roller?
I don’t want to reset I need to remove the brushroller to clean the housing behind the roller from buildup
Esta é uma boa pergunta?
Pontuação 2
1 comentário
I've been searching trying to find an answer for the exact same thing. You could just remove the belt on my previous Dyson but this one has a plastic cover over it that I can't figure out how to remove for the life of me. Even Dyson has no instruction on removing the plastic cover over the belt. I'm assuming they don't want you to remove it.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Here’s a video on how to do it.
https://www.youtube.com/watch?v=kQ7OynOR...
Esta resposta foi útil?
Pontuação 3
1 comentário:
This is not what he and I are trying to do. We know how to clean the beater brush. What we want to do is to REMOVE the beater brush but there is a hard plastic cover over the belt which there are no instructions o how to remove. Have found no videos either. Everyone just wants to show you how to clean of hair.
por
This might be able to help you…
https://www.youtube.com/watch?v=yERbv8ow...
Dyson really went to far in designing replacement parts. It seems to me that they don’t really want you to tinker with the individual parts in the head assembly as it come as a whole replacement.
Good luck!
Pontuação 1
1 comentário:
I believe you are correct. The only way to get the clear plastic cover over the beater to be clean is to replace the entire vacuum head. Maybe my OCD self with have to paint over that clear plastic cover so I don’t have to see the filth.
When it comes time that the entire vacuum head needs replacing, I’ll buy a new vac instead. Probably a model that I can at least clean it at home.
por
Adicionar a sua resposta
Renissa Seekings será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 13
Últimos 30 dias: 57
Ao todo: 6,317
