Ir para o conteúdo principal
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
20 Perguntas Visualizar todos
Tab 10.5 will not start up
Tab 10.5 died and will not turn back on. Charged and tablet will show 100% charged only. Nothing else.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Might want to check your Owner Manual on how to access the Recovery menu. Usually it's press and hold the Volume up button and at the same time press the Power on button. Keep holding until the Recovery menu appears.
Galaxy Tab S 10.5 Troubleshooting may also have some information
If you can't access the recovery menu then it's likely the electronics are malfunctioning
por
Adicionar um comentário
1 resposta
Connect the tablet to a wall power source using the wall charger and cable.
Wait for about 10 minutes to ensure the tablet has gained enough power to start.
Press and hold the “Volume Down” and “Power” buttons simultaneously for about 10 to 15 seconds..
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ron19cam48 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 69
