Why restart when I connect the charger?
Hy i have iphone 6 and i replaced a the battery and if i connect the charger then the phone keep restarting and i cant do with it. Any idea to fix tish problem , i rested a phone .
Esta é uma boa pergunta?
Sounds like you may have a defective replacement battery or something on the logic board was damaged either during the replacement or was the root cause for you needing to change the battery in the first place.
If the old battery still worked, even if with reduced capacity, I would install it to see if the problem persists. You need to eliminate some variables here and give more information on why you had to change the battery in the first place.
Esta resposta foi útil?
I try with the old battery and same thing .But i try to backup the ios and i got error 9 and the phone after boot just black screen.
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 40
2 comentários
Strange one?? Just to get it correctly the phone does not restart until you plug the charger in
Am I right??
por edigitcom
Yes its very strange .
por Rods James
