Ir para o conteúdo principal
The Nikon D60 is a 10.2-megapixel Nikon F-mount digital single-lens reflex (DSLR) camera released in January 2008. The D60 is the successor to the entry-level Nikon D40x.
Spots on my photos, and my lens and reflctor are clean
What could the problem be? I was told it might be the sensor, but how do I clean that?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
you might want to check the Owner Manual for "bright spots" and how to reset the camera to factory default settings before attempting to disassemble your unit. A copy of the manual in PDF format can be obtained at the following link:
https://www.camerauserguide.net/nikon-d6...
por
Adicionar um comentário
2 respostas
Pergunta mais útil
@kenuto if everything checks out than it is possible that this is caused by dust etc on the CCD sensor. Let us know if you are up to replacing it. Cost is around $70USD
Esta resposta foi útil?
Pontuação 2
Is your actual sensor clean? To get to it you have to go into the menu, select the wrench tab, scroll down to mirror lock up, enter that, click OK to turn it on, then you get a message about using the shutter button to lift it, then remove the lens with camera pointing down and you can use an air blower to blow the sensor off. once done, turn the camera off and replace the lens.
Pontuação 0
Adicionar a sua resposta
Kenny será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 20
Ao todo: 436
