Ir para o conteúdo principal
The Nikon D60 is a 10.2-megapixel Nikon F-mount digital single-lens reflex (DSLR) camera released in January 2008. The D60 is the successor to the entry-level Nikon D40x.
4 Perguntas Visualizar todos
Spots on my photos, and my lens and reflctor are clean
What could the problem be? I was told it might be the sensor, but how do I clean that?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
you might want to check the Owner Manual for "bright spots" and how to reset the camera to factory default settings before attempting to disassemble your unit. A copy of the manual in PDF format can be obtained at the following link:
https://www.camerauserguide.net/nikon-d6...
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@kenuto if everything checks out than it is possible that this is caused by dust etc on the CCD sensor. Let us know if you are up to replacing it. Cost is around $70USD
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Kenny será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 215
