Ir para o conteúdo principal
Informações e guias de reparo para a versão CDMA da quarta geração do iPhone. Modelo: A1349 / 8, 16 ou 32 GB de capacidade de armazenamento
Power button not clicking after disassembling
Ok, so I was attempting to do a screen replacement on a iPhone 4 CDMA, and i wanted to disassemble the power button as it was not clicking before. However, once i took the physical power button apart and checked the power cable flex, everything seemed tip-top. Only problem i have is when i tried putting it all back together, after screwing everything back in and aligning the power button, as it was crooked, the satisfying click wasn’t there and I do not know why. I re-disassembled again and check the ifixit guide here to see if i didn’t miss a step or whatnot. Click was still not there. Is there like a part that i’m missing to get that click or do i have replace something to fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Did you place the small back plate in-between the cable and the plate ??
Esta resposta foi útil?
Pontuação 0
1 comentário:
there's a backplate sandwiched to the power button and the device?? I'm not sure, i have to check for myself
por
Adicionar a sua resposta
Juan Jimenez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 249
