LI2000 internal parts schematic
I took apart a LI2000 screwdriver and can’t get it back together correctly. Is there an internal parts schematic available?
Esta é uma boa pergunta?
None of the information/tutorials at the following of use?
Could also search for your unit and an exploded diagram or teardown at Google Images; might be something available.
Or is it the actual electrical schematic you are after?
If no luck with the above you may want to attach some photo's detailing your problem in order to aid other participants to help you fix your unit. See
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 632
