Ir para o conteúdo principal
iPhone flash and silence button
Hi,
so I recently changed my back shell of my iPhone and did it in a bit of a rush so messed up a few things… the flash no longer works and the switch on the side of the phone doesn’t work. Any ideas? The only thing I know I did wrong was the plastic part in the top left of the iPhone I damaged but I don’t know what that part is to order a new one!
thanks
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Might want to look at the following tutorials to see if you recognize the damaged component (the teardown tutorial might be good for a quick run through):
iPhone 6s Plus
por
I did have a look but they don’t mention the part
por
Adicionar um comentário
1 resposta
Pergunta mais útil
You may have damaged the Power Button/Flash Flex. Take a look at this guide to find it and do a thorough visual inspection of the flex, especially along the bends. Look for tears, even the slightest bit and replace as necessary.
Esta resposta foi útil?
Pontuação 2
2 comentários:
thanks, but could you tell me what the part does thats a black box at the top left of an iPhone 7 plus
por
The flex has the power button, flash and rear microphone.
por
Adicionar a sua resposta
Ed harris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 84
