Ir para o conteúdo principal
Portable, Bluetooth, water resistant speaker. Manufactured by Sony in 2017.
Also fried something. useless words to get five
Hi, I accidentally put a 12v charger into my xb30. Now when I put in the right charger the battery indication turns on for about a minute then turns of. the middle buttons on top doesn’t work and the lights doesn’t turn on. Extra bass, the on button, pairing and the sound still works.
appreciate any help
Thanks // Kalle
Update (06/10/23)
First of I’m sorry for the very late reply to such a helpful answer. I’m so grateful that there is this help to get, and to create a fixing culture when there is so much waste of stuff is inspiring.
I had another speaker of the same kind so I never got around to cracking this thing up. Now I found out a friend that was living in my house accedentily put a 12v charger in to my other one, so this happened again haha🤦‍♂️ this one is completely dead now. Anyways I have opened it up and sitting with the parts in front of me. I’ll send over some pictures of the charging board if that is what you meant.
Thanks a lot/ all the best Karl
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Pretty well much all you can do except take it in to a repair shop:
My speaker also doesn't switch on , I used the wrong charger
por
Adicionar um comentário
1 resposta
Solução escolhida
ksunnefeldtnyberg  sounds like you may have fried parts on the power board. You will definitely need a new battery.
We would have to see what the boards looks like. Use these guides Sony SRS-XB30 to disassemble your device and take plenty of good pictures of your board, that way we can see what you see and hopefully identify the issues. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 2
3 comentários:
@ksunnefeld27168 life happens :-) pictures will help so we can try and assist with this
por
Yes Thanks for understanding. Nice to see you are still around helping out:) sorry thought I did but see that I just uploaded them to the media browser, I’ll try again
por
@ksunnefeld27168 post one more of the underside and do you see anything "odd" under the foam tape?
por
Adicionar a sua resposta
ksunnefeldtnyberg será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 183
