Ir para o conteúdo principal
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
20 Perguntas Visualizar todos
My phone turns off after 3 minutes
Im not sure if your able to help, but i have an iphone xs max and i did a charging port replacement pretty easy but the phone stays on for 3 minutes and shuts off battery status seem to be correct everything work it just shut off after 3 minutes what do you think causing the issue and how to fix it
Esta é uma boa pergunta?
Pontuação 3
2 comentários
I have one doing the same thing it cuts off the powers right back on is this what yours is doing???
por
I changed the screen on mine and after 3 mins mine does the same -.-
por
Adicionar um comentário
2 respostas
Solução escolhida
I would try to re-install the original charge port to see if the problem persists. If it does, then you may have accidentally damaged something on the logic board (connectors) or one of the flexes. If the problem is not present with the original flex, then you probably have a defective replacement flex.
Esta resposta foi útil?
Pontuação 2
Has anyone figured out the fix for this? After charge port replacement i am having same issue
Pontuação 0
Adicionar a sua resposta
Benny Jelleh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,338
