Ir para o conteúdo principal
O Microsoft Lumia 540 é um smartphone de baixo custo identificado pelo número de modelo RM 1141.
How can I Recover data without PC?
Hello.
So I have a Microsoft phone (model: RM-1090)
And there is an issue. I need to recover files and images because they were deleted after a hard reset. Problem is, that I cannot charge this device with an ordinary charger because the usb (on the device) is not functioning. So everytime I want to charge the device I have to manually remove the battery and charge it, in an external charger.
The usb not functioning means that I cannot connect my phone to a pc so I can recover the data.
Is there any way, to do the recovery procedure inside the phone without using pc?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi ,
Since the phone is working have you thought about using Bluetooth to transfer content etc to a paired BT device?
Here's a link that may help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
GO4GAME será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 25
Ao todo: 466
