Ir para o conteúdo principal
Guias de reparo e informações de desmontagem para smartphones Wileyfox.
removing battery on swift 2 +
the tear down is on you tube, but the battery removal from the face is done by using thin sheets of plastic sprayed with a liquid which is not identified in the video, it looks like water but may not be something electrically non-conductive
does anyone have a clue to this liquid please ?. thank you. Ben Littlewood.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@beng0plo looks like its needed to loosen the adhesive strips. This iFixit Adhesive Remover an some of those Plastic Cards should work perfect for this.
Imagem de Handy tool for opening devices, spreading thermal paste, and scraping. Same as Apple Tool Part# 922-7172
Produto
Plastic Cards
$2.99
Imagem de Soften adhesive to make prying and separating electronics components easier.
Produto
$19.99
Esta resposta foi útil?
Pontuação 3
1 comentário:
Many thanks for your help. I have ordered the kit, and will advise you how I get on thanks again. Ben.
por
Adicionar a sua resposta
ben será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Ao todo: 858
