gas leaks from carb
when i turn the fuel on gas well leak out of the air box
Esta é uma boa pergunta?
@baylor we would at least need to know what model and year your bike is and what you have checked. Most common problem is a stuck needle valve that will then disable the float and causing the carb to flood. Check that first,
Esta resposta foi útil?
03 triumph America . hears what’s going on i’m trying to get running witch I did the bike went thew katrina and my buddy got it for parts for he’s bike all he needed was the front tire .he gave me the bike so I could get it running . witch I did . we rebuilt the carbs and set them up . we tested them before we put them on the bike and they we had no problems .put them on the bike and they pee out the airbox . we’ve had them on and off at least 4or 5 times and reset them .and yes new needle values.
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 22
Ao todo: 407
