Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Perguntas Visualizar todos
Logic board compatibility 30GB in 60GB
I have an Ipod Classic 5th Gen A1136 and I pulled the battery connector from the logic board while removing the cable. That’s what you get for rushing :) I am wondering if a logic board from the 30GB Ipod of the same generation will fit into mine ? I believe that the 30 and 60GB use the same early board and are compatible but prefer to check before purchasing the 30GB one. Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@pedro147
yes it does. no issues there.
Esta resposta foi útil?
Pontuação 1
4 comentários:
Man that was quick, I hadn't even logged out yet @oldturkey03 :) I was just reading about some HDD upgrades as well and you have contributed some valuable answers there too. I thank you and have a great weekend.
por
@oldturkey03 if you are still around, I was just thinking that seeing as the Ipod I might buy appears to have a better LCD screen than mine, can I just put my 60GB HDD straight into it please ? I would assume so from what I have read here. Thanks.
por
@pedro147 yes you can. If your original iPod was a 60GB you are okay, if it was a 30GB you need a thinner battery (the one for the 30GB is thinner so stick with it)
por
Adicionar a sua resposta
Peter Newman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 243
