Ir para o conteúdo principal
Repair information and troubleshooting for the Dell Latitude E6430. This business class laptop has a 14 inch screen and uses a 3rd generation Intel Core processor. It was announced in May 2012.
Horizontal line going from end to end on the screen
I have a dell latitude e6430 and there is a line running from end to end on the screen. I think its stuck pixels. When the screen is white the line turns red and any other coulor the line is green. How can I fix this? (The line next to the queen playlist is just spotify.)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Just from the pictures I would say that there’s a problem with the LCD display itself. It is either a bad controller chip or the LCD element has pulled away from the contacts to the controller. I’m afraid it may not be repairable. Definitely check with Dell.
Esta resposta foi útil?
Pontuação 2
2 comentários:
It just fixed itself.
por
Glad to hear it but it probably won’t last. If it comes back try GENTLY squeezing it (front to back) on the edges where the defect is. This is a common aging problem with LCD displays. Replacement is about all you can do. Best of luck.
por
You have a TAB (tape automated bonding) failure on the LCD. Even if it comes back temporarily, you need a new LCD, like it or not.
Refer to this video to replace the LCD.
Pontuação 2
Adicionar a sua resposta
Panayiotis Michalos será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 241
Ao todo: 1,166
