Ir para o conteúdo principal
O Sony TCM-919 é um gravador de cassetes portátil e leve com capacidades de gravação de áudio. Este dispositivo dos anos 1990 está equipado com um contador de fita de 3 dígitos, microfone, desligamento automático e um sistema de alto-falante frontal.
Cassette player does not turn
The unit is actually a tcm 450 but the particular model was not present on the selection list. I found it in my grandma’s drawer along with a bunch of tapes, and I’m pretty sure it worked a year ago or so. when I shoved a tape in with aaa batteries, nothing happened. I removed the tape to see if the knob thing inside was turning, and it didn’t. Ibplayed with the volume knob and all the buttons, but it was failing to work. I can feel that the cassette player is trying to make it rotate— I can feel it when I touch it with my finger while pressing the ‘play’ button, but yet, nothing is happening. Plz Help!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @pxlbluejay ,
Here’s a link to the service manual for the cassette player.
It has full schematics of the player which should help you find out where the problem lies. If a component is faulty it also has the parts list.
Hopefully this is a start to get the player going again
Esta resposta foi útil?
Pontuação 2
1 comentário:
jayeff,
thanks a lot!
por
Probably a bad drive belt. If you can open it up and take a look chances are that the old rubber belt has gone soft and stretchy, without the right tension the motor wont be able to drive the pulleys. You might hear a mild screeching noise when you hit play, most likely the belt skipping. You can buy replacement belts on ebay or maybe amazon.
Pontuação 0
Adicionar a sua resposta
Jay Kwon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 1,440
