Ir para o conteúdo principal
O Motorola Moto Z3 Play foi lançado em junho de 2018. Ele possui uma tela de 6 polegadas e uma bateria de íons de lítio (Li-Ion) de 3000 mAh não removível. Sua câmera traseira é de 12 MP e sua câmera frontal é de 8 MP. Números de modelo: XT1929-3, XT1929-4 e XT1929-8. "XT1929-3 NA XT1929-4 NA XT1929-4 NA XT1929-5 LATAM XT1929-6 LATAM XT1929-8 EMEA/APAC"
Screen replacement causes digitizer to not work
We are a repair shop and we have tried replacing the screens on this model a few times xt1929-17 and every time the digitizer doesn’t respond on the new lcd has anyone experienced this issue or come up with a fix?
Esta é uma boa pergunta?
Pontuação 10
Adicionar um comentário
2 respostas
I am also experiencing this issue! The digitizer stops responding once you turn the phone off and then back on… it’s a little annoying to say the least. Any guidance on this would be awesome!
Thanks
Esta resposta foi útil?
Pontuação 0
1 comentário:
I’ve researched and asked local shops as well most have just blamed it on the current quality of the parts on the market being low. Are shop has suspended repairs at the time do to the large warranty rate of the XT models
por
You have to do a hard restart. It’s the only way I’ve found to do it.
Pontuação 0
2 comentários:
Could you clarify how you did that? I had the battery cable disconnected, replaced the screen with no problem, and turned the phone on without issue. The problem is that the touch doesn't register, no matter how many times I fiddle with the battery. This was a straightforward, easy fix up until this point.
por
When he says hard reset, he's likely referring to a factory reset.
I haven't replaced the screen on this device yet, but I plan to soon. I'll let you know if I run into this issue and have I might fix it.
por
Adicionar a sua resposta
Mike Henry será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 1,316
