After similar experience, I disassembled my base unit and discovered a melt down of a capacitor on the main PC board. This is the message I sent to Bose:
Hi, Prior requests for support have not let me to a fix. Spare time has led me to try to repair my BOSE Unit myself. Disassembly reveals that I have a failed Nichicon capacitor, labelled 15000 µF, 25V, 22mm dia, 45 mm height & marked VZ(M) 105°C, in the main PC board. Photos are attached. It leaked a white sticky, pasty goo, apparently from the end opposite the pins, and appears melted to an amber colored resinous solid at the base. A 2nd similarly labeled capacitor in the unit, in the sub-board that attaches to the power, speaker & control unit, shows no similar leakage of white goo or resinous colored solid/ deformation at the base.
Using the finder at https://www.mouser.com/Passive-Component... which lead me to https://www.mouser.com/ProductDetail/Nic... , I think it is Mfr. #: UKT1E153MRD, Mfr.:Nichicon. I hope you will confirm the specification so I can order a new one and install it. I can solder, and it appears to be a straightforward replacement of a $6.23 part- what do I have to loose?
In exchange for your assistance, I free and release Bose from all liability.
The unit is a BOSE 321 series base module 321 GS Series II, bought at the Bose store in Manchester VT 12/28/2005, Customer serial # 03566695715622AZ, S/N 034200950062395AY.
Thanks
So far, no help from Bose. I'm searching for the replacement capacitor, will install it and see what happens…
3 comentários
Hi
I had similar problem. I can’t power it on.
I checked continuity on cables and power to unit. Everything is ok. I’ll check fusible, soon. This is something that I learned from previous questions. Let me know if you have solved your problem.
por Walter Martin
Took my unit to my "go to" electronic expert. He had difficulty finding any Bose manuals to assist him. Said some stuff Bose does/did, was different from his training/experience (old Navy guy with decades of experience). He told me everything he tested was good - so problem is something he can't find without diagrams. I've tried holding various combinations of buttons in an effort to re-boot/reset, etc. Still comes on with a pale green light (no lettering), then fades out after about five minutes. Very disappointed with Bose.
por Steve
I'm having the exact same problem. Did you guys ever have any luck finding a way to diagnose or repair?
por Brittany German
