Ir para o conteúdo principal
Repair and troubleshooting information for the Dell Inspiron 15 5577, a gaming laptop with a 15.6 inch screen.
10 Perguntas Visualizar todos
I accidentally spilled my drink on my computer.
So yh i spilled my drink on my laptop. I turned off the computer and started to dry it. I opened the back cover and removed the battery. I let it dry for some hours and put everything back when it was dry. When i try turning the laptop on nothing happens. :( Did something fry in my computer?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Do you have any way to test if the battery itself is still working?
por
Not any that i could think of :(
por
Adicionar um comentário
1 resposta
Solução escolhida
Light Hikari  the last thing you want to do is to turn it on. At this point you will have to disassemble it and clean everything with some high grade 90%+ isopropyl alcohol. Check your motherboard for any obvious damaged looking parts. Only after you cleaned it properly would I try to restart the computer. For now you must consider it a shorted out motherboard. Dell Inspiron 15 5577 Gaming
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Light Hikari será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 208
