Ir para o conteúdo principal
itunes error 4014 and replaced NAND already
iPhone came in with error 4014. Tried several computers and cables restoring first. Measured the voltages according to schematics and they all had value. I reballed the NAND and it gave me the same error. Checked the pads underneath and non were missing/damaged.
Placed another NAND from an icloud board and still the same error. I searched online and some say it could be BBPMU which I also replaced. I am running out of ideas. Could I have been unlucky and placed an faulty NAND
This is my first attempt fixed error 4014. Maybe I missed something?? Any tips what I could check before sending it to China for a boardswap?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
You have to reprogram the NAND before installing it on your device. Also check your main NAND lines (PP0V9 and PP3V0) as well as PP1V8. If you remove the NAND again, check the pads in diode mode. Anything connected to the CPU should give you some kind of “normal” readings - check XW for expected readings.
Esta resposta foi útil?
Pontuação 2
6 comentários:
The 3 lines all have the correct voltage. I thought I could just restore the iphone. Itunes recognizes the iphone in dfu mode. The NAND is wiped
por
The NAND has to be programmed via a special programmer, such as this one: JC Pro 1000S / P7
por
Oh I have this machine but the original NAND cannot be read. Thats why I wiped the new one. It doesn't work if I use a empty NAND and itunes to restore it?
I get a 4014 error when I try restoring with the empty NAND which suggests NAND problems. Is this because it's empty or is there something else causing this error.
por
If you could not read the original nand you will have to manually input the IMEI number and Mac Address into your programmer and write it to the new nand.
por
Late update, I took the info of an spare NAND I had and wrote its info on the wiped NAND. So I guess a nand cannot be empty when you restore??
Itunes restored the NAND without problems. It could not be activated because the serial and wifi address didn't match.I wrote the original serial and wifi address back and it asked me for the icloud info which I m waiting on so it should work now
por
Exibir mais 1 comentário
Pergunta mais útil
Have you tried another charging IC (tristar)? Sometimes these can cause weird problems with restores on iPhones as that chip is responsible for USB communication and not just charging.
If not, you may want to replace the charging chip (try another charging port assembly first before doing so in case of a bad charging port).
Pontuação 2
1 comentário:
It was the empty NAND that gave the error.
por
Adicionar a sua resposta
KWH será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 4,102
