Ir para o conteúdo principal
Sound, no screen display
Greetings. About thirty minutes ago, I dropped my iPod Touch. The screen went black and the glass top began to peel off. I pushed the glass top back in place and the display showed. However, I could not see what was on the left side of the screen, as it shined a bright grey with dozens of brightly-coloured lines. Thinking the issue could be fixed by simply pushing the screen back into place again, the display finally shut off. I am still able to hear the sounds of the iPod locking and unlocking, etc., so it seems to be an issue with visuals only.
Any help would be greatly appreciated. Thanks.
- ZM
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like you need a new display. The "grey with dozens of brightly-coloured lines" was where is actually broke. The pushing in may have just temporarily bridged some open connection, which ultimately failed. Of course you should disassemble it and make sure that all your logic board connections are still set, but I'd go for a new screen
iPod Touch 3rd Generation Display Replacement
iPod touch (3rd Gen) LCD
Imagem de Replace an LCD display compatible with the 3rd Generation iPod Touch model A1318.
Produto
$24.99
Esta resposta foi útil?
Pontuação 2
3 comentários:
Other sources have also told me to open up my device, but I've decided to send it in to be repaired instead. Thanks.
por
Alrighty Zander, best of luck to you and your iPod...;-)
por
Thanks much.
por
Adicionar a sua resposta
Zander M será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 1,281
