Ir para o conteúdo principal
Modelo A1369, processador de 1,6, 1,7 ou 1,8 GHz, armazenamento flash de 64, 128 ou 256 GB
Retrieve data from SDD on MacBook Air 2011
Is there a way to retrieve data from an old Samsung SDD taken from my Mac Air 2011? The Mac was totally dead after water damage but I want the photos. I have now taken the SDD out and thought perhaps there is a caddy I could buy, etc.
Imagem
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Solução escolhida
You need an OWC Envoy enclosure
https://eshop.macsales.com/item/OWC/MAU3...
https://www.adorama.com/owcmau3evy11.htm...
Esta resposta foi útil?
Pontuação 6
10 comentários:
Thanks Mayer. Just ordered!
por
Hey Alan - did it work? I'm wondering if I can get data off of a 'dead' SSD...
por
@kdnavrat - I'm sure it worked! I've salvaged a few wet systems data using the OWC Envoy cases. The only issue is how wet your SSD got as salt water will do a number of the traces.
por
Oh sweet! I'll try it. I just ordered an OWC Envoy enclosure and I assume I just put the 'damaged' SSD in it and see what I can find? Thanks
por
I can't get the Mac to "see" the SSD in the OWC Envoy - it acts like it just can not be found. Any suggestions?
por
Exibir mais 5 comentários
Adicionar a sua resposta
alan s. será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 37
Ao todo: 793
