do package unit air conditioners come pre-charged with freon
do ac unit package style come pre charged with freon
Esta é uma boa pergunta?
package ac units are typically sold already charged with refrigerant. Set them in place, wire them up with control voltage and high voltage, plumb them for drain lines, and they should be ready to go. Every one I've installed was already charged to the manufacturer's specs. Unless there's a leak. Then you have to find and repair, then recharge to the weight specified on the data tag.
Esta resposta foi útil?
steven sasser
not quite sure what you are referring to by “ac unit package style” No, it is not pre-charged if it is for an outside unit. Let us know exactly what you are going to replace.
Window or pedestal units are charged.
Split systems (cooling lines between the outside compressor and your house's air handler) won't be.
it really depends on the refrigerant type and manufacturer. Split units that are r410a typically have a factory charge in the condenser unit. R22 units come with dry nitrogen.
When they say a package unit they are referring to the units typically used in commercial applications where the air handler/furnace and the condenser are combined into one unit. And they are normally precharged from the factory data tag on the unit will specify what weight of refrigerant is in each circuit.
Package unit air conditioners may or may not come pre-charged with refrigerant, including freon, depending on the manufacturer and the specific model. It is important to check with the manufacturer or consult with a licensed HVAC professional to ensure proper refrigerant charging for optimal performance and to avoid potential damage to the unit.
As far as I know, package unit air conditioners usually come pre-charged with refrigerant. It's part of the installation process to ensure they're ready to go right out of the box. If you're thinking of getting a package unit AC, it's always a good idea to double-check with the manufacturer or the HVAC technician to confirm this.
I'm just sharing what I've learned. If you need more tips or information, you should check out the free AC estimate webpage. They might have some helpful insights for you. Sorry for the delayed response, but I hope it can still be useful for others reading this thread.
Últimas 24 horas: 7
Últimos 7 dias: 60
Últimos 30 dias: 227
Duração total: 6,091
