screen not responding to touch
I have replaced the screen 2x and the touch used to work but not always then it stoped working and Im sure its not a touch disease
Esta é uma boa pergunta?
Touch Disease is a common failure on the iPhone 6 Plus.
At first, the phone will typically develop intermittent touch control failure. For some phones, a gray/white bar starts appearing at the top of the screen. Twisting and applying pressure in certain spots sometimes allows touch control to work for a short period of time, but eventually, the touch interface ceases to function entirely. This is colloquially known as Touch Disease. You can look at my profile for a link to a blog article on Touch Disease or search the web for more info.
Ideally, you need to isolate a variable and either identify a known-good screen or test your replacement screen in a working phone.
If you are confident that your replacement screen is fully functional and there is no damage to the Digitizer FPC connectors on the logic board, then your phone probably suffers from Touch Disease. This is not a DIY repair.
Look for a repair shop that can do micro-soldering repairs to properly diagnose your problem.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 74
