Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
873 Perguntas Visualizar todos
Battery Percentage Stuck On 1%
Hi everyone, Hi @refectio Sir. I have an iPhone 8 for reparing, who won’t charge. The charging percentage remain 1%.
The phone is in bad condition.
Q3201 & q3200 in missing.
C3292
C3293
Are missing also.
For capacitor and and q3200 is not problem.
The problem is : Q3201 has PAD 2 & 3 missing.
There is only solution, need jumper to any place where they are connected or
I can do something else??
I can’t find iPhone 8 Schematic? find only 8 plus.
Is 8 and 8 plus schematic are same?
Thanks everyone.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
You definitely need to get Q3201 installed properly. There is no schematic for the iPhone 8 available but the iPhone 8 Plus works fine for most of the “compute” sections of the phone. The battery SWI/HDQ communication configuration is the same electrically speaking between both devices so you just need to apply the wiring logic from the 8P to the 8 (via ZXW).
Esta resposta foi útil?
Pontuação 2
2 comentários:
@refectio sir :) thank u very much
por
So who is posting identical questions to yours in Facebook Groups but under a different name?
por
Adicionar a sua resposta
AGS será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 9
Duração total: 1,663
