Ir para o conteúdo principal
This device is a personal paper shredder manufactured by Fellowes, Inc. in 2005. The shredder has the capability of shredding 7 sheets of paper at once as well as credit cards, identification cards, and cards likewise of the same thickness.
6 Perguntas Visualizar todos
Where can have my Fellowes W11C repaired?
The sensor that turns shredder on is broken, so when I stick a piece of paper in the machine will not start. Where can I get this shredder repaired? Replacement part? Can I repair this myself?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@x41perch take a look at this guide. Even so not specifically for your model, the shredders should work in pricipal the same Fellowes T7CM Trigger Sensor Replacement
Take pleny of pictures when you take yours apart and you can post those with your question Adicionar imagens a uma pergunta já existente Creating a new guide would even be better https://www.ifixit.com/Guide/new
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Fellowes T7CM Trigger Sensor
Guia
Fácil
1 minute
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Bob Malwitz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 673
