Introdução
This guide will show how to remove the trigger sensor in the Fellowes TC7M paper shredder.
O que você precisa
Check to make sure the shredder is not plugged in to any electrical outlet.
Remove the shredder from the catch basket and place the silver side down on a flat surface.
Place the catch basket aside as you will not be needing it for the rest of the disassembly.
Flip the shredder silver side down and place on a flat even surface.
Remove the manufacturer's label in order to gain access to the hidden screw hole.
Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
Remove the wire holder. This is a small screwed in piece of plastic which holds the wires in place. The screw length is 10 mm and the head diameter is 6 mm.
Remove the screws holding the feeding sensor in place. The screw length is 10 mm and the head diameter is 6 mm.
Lift and remove the sensor.
Replace the faulty sensor with a new sensor.
