Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1199 Perguntas Visualizar todos
iPhone X Bootloop earpiece flex cable issue 4013
I had the same issue as described in the thread I will link below.
iPhone X in bootloop, error code 4013 in iTunes and nothing would help to restore EXCEPT disconnecting the earpiece flex cable. I disconnected it and the phone booted up. However, when I reconnect the flex cable, the phone will not boot up anymore.
Any suggestions?
IF I connect the earpiece to the logicboard AFTER the phone is booted up, the phone continues to work and the earpiece works too. Face ID doesn’t. It doesn’t shut down automaticly or anything. Did anyone have this issue before?
iPhone X Error 4013
Esta é uma boa pergunta?
Pontuação 1
1 comentário
An update: I bought a new earpiece flex module, with the sensors and it seems to boot up with that one connected. SO what can I do now to replace, and have faceID still working?
por
Adicionar um comentário
1 resposta
Solução escolhida
The iPhone X logic board is very susceptible to damage following a drop due to it’s sandwiched, dual circuit board design. Some cracked solder balls along the terminations can cause Error 4013. That’s not to say this is your specific issue but if modular or software approaches don’t solve the problem, the next step is to have it looked at by an experienced micro-solderer.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you for your reply. I was afraid that I would need the help of a micro-solderer too. The only thing that I find so weird is that my iphone is working perfectly after reconnecting the earpiece to the logicboard after the phone booted up.
por
Hi
i have exactly the same issue.Since i open the phone and i put the cable of eearpiece, the phone does not loop.Did you find any soltuion in this matter?
por
Adicionar a sua resposta
Kelvin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 1,150
