Ir para o conteúdo principal
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
Power on but no singnal to monitor or keyboard
Hi!
I bought a new motherboard, cpu and ram to my PC. When I connected everything to the computer I turned it on but i had no singnal to my monitor or keyboard.
Spec: CPU: I5-9600K RAM: HyperX Fury DDR4 3200MHz 16GB Motherboard: MSI Z370I Gamin Pro Carbon AC GPU: EVGA 970
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Have you made sure the display cable from monitor is plugged into the back of the graphics card and not behind the motherboard?
Also try reseating all the power cables to the motherboard and graphics card.
Esta resposta foi útil?
Pontuação 1
5 comentários:
I have tried both and all cables heve been checked and reconnected. No luck.
por
Hi @rianthelion ,
Have you got a speaker connected to the motherboard?
If not connect a speaker to the motherboard's speaker header pins and check if there are any beeps on startup
JFP2 connector :
pin 1 Speaker -ve
pin 2 Buzzer +ve
pin 3 Buzzer -ve
pin 4 Speaker +ve
What type of keyboard is connected PS/2 or USB?
por
No beeps, The USB ports on the motherboard is dead no sign of power. I tried different this keyboards phone charger etc.
por
Hi @rianthelion ,
Try disconnecting/removing all except PSU, RAM, keyboard and monitor from the motherboard, i.e. barebones PC - no HDD, no ODD no GPU card etc and check if you get display and can get into BIOS OK.
por
Found the problem! The motherboard don't have support for 9th gen Intel prossesor you need to update bios first. Buying a cheap celeron so I can uptate bios. Thanks for your help!
por
Adicionar a sua resposta
RianTheLion será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 864
