Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Perguntas Visualizar todos
MacBook Pro BlackScreen No Backlight, Keyboard Backlight, OR Video Out
During normal usage (surfing internet / email / etc) not connected to power adapter, the screen went black. For the life of me, I can’t remember if everything stopped at that moment, or if it was just the screen, and in turn if I forced shutdown or if it shutdown on it’s own. I hit the power button to boot and I hear the chime, but I do not get any backlight on the screen, no backlight on the keyboard, no lights (cap’s lock) on the keyboard.
I know the keyboard works because it is registering me resetting the SMC and PRAM. I will hear the chime every time the PRAM is reset or the computer is turned on. I have tried letting the computer stay “on”, as confirmed by fans running, to completely drain battery. Tried connecting computer to adapter and resetting SMC and PRAM then, but still no backlights, no video, nothing.
I have also tested connecting the computer to my thunderbolt display via thunderbolt port as well as an HD TV via HDMI port with nothing going through.
About a month ago I replaced the battery. Nothing was out of place and everything was working perfectly until today. I have also opened up the computer to make sure all connectors were good.
Any other ideas of what could be going on? I have an idea but don’t want to lead my question either.
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
Are you able to gain access to yourMacBook Pro from your other Mac system using Target Disk Mode?
The Ins and Outs of Your iMac’s Target Display Mode
por
Thanks for the response Dan.
I have connected both computers via Thunderbolt. I have booted my other Macbook Pro to select its disk both before and after turning the troubled computer on. During boot, I held down "T" on the troubled computer with nothing working.
I have also tried it in the other direction, booting the second macbook in target disk mode and starting the troubled computer and pressing option to select disk.
Neither of these options are working in either direction.
por
Adicionar um comentário
2 respostas
OK lets try one last test: Disconnect the battery and then with the battery and MagSafe disconnected press and hold the power button for a good minute. Then plug the MagSafe charger in your system should spontaneously start. Your MagSafe chargers LED should be Amber. If this fails your logic board is in need of serious repairs, it maybe easier to just replace the logic board. Review the guide here for your board MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement
Esta resposta foi útil?
Pontuação 0
2 comentários:
Doesn't seem like that worked either. From my searching, I am guessing it is broken solder connections on the graphics card. I am seeing that issue occurs quite a bit with this particular MBPr. Thanks for taking the time and suggestions Dan!
por
Well, its true some systems will encounter GPU issues. Often on systems that get overstressed like heavy graphical gaming. It can be within the chip or the connection to the logic board.
I'm not sure if thats your issue though... If you reset SMC then you should have been able to connect your other system to using Target Disk Mode as unlike the OS boot up will by pass POST allowing the system to be accessed with a bad GPU.
Try again, if you still can't get in then you have a deeper issue than the GPU.
por
Any solution to this problem.. i have the same issue
Pontuação 0
1 comentário:
I had to send out the computer to have the logic board re-soldered. Cost me about $300+
por
Adicionar a sua resposta
kochanowskibenjamin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 451
