Ir para o conteúdo principal
MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement
O que você precisa
  1. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
    Pergunte ao FixBot
    Comentar
  2. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 2, imagem 1 %32
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
    Pergunte ao FixBot
    Comentar
  3. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Battery Connector: passo 3, imagem 1 %32
    • Peel back the warning label covering the battery connector.
    Pergunte ao FixBot
    Comentar
  4. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 4, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 4, imagem 2 %32
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    Pergunte ao FixBot
    Comentar
  5. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, AirPort/Camera Cable: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
    Pergunte ao FixBot
    Comentar
  6. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 6, imagem 1 %32
    • Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
    • The plug in the photo has six connections, but some models have twelve connections. The process of removing the plug from its socket is the same for both.
    • If the camera cable's plug won't come easily out of its socket on the logic board, fold back the rubber cover over the fan to gain access to the cable, then gently pull on the cable while using the spudger to gently push the plug out of its socket.
    • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the plug out of its socket. Do not pry up, or you will damage the socket.
    Pergunte ao FixBot
    Comentar
  7. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 7, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 7, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 7, imagem 3 %32
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and flip it back so that you can access the cables underneath.
    Pergunte ao FixBot
    Comentar
  8. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 8, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 8, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 8, imagem 3 %32
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    Pergunte ao FixBot
    Comentar
  9. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, I/O Board Cable: passo 9, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, I/O Board Cable: passo 9, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, I/O Board Cable: passo 9, imagem 3 %32
    • If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched.
    • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
    • During reassembly, connect this end first, as it does not flex.
    • In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
    • Remove the I/O Board cable from the MacBook Pro.
    Pergunte ao FixBot
    Comentar
  10. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Airport Card: passo 10, imagem 1 %32
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort card to the logic board.
    Pergunte ao FixBot
    Comentar
  11. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 11, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 11, imagem 2 %32
    • Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
    • Pull the AirPort card parallel out of its connector on the logic board to remove it.
    Pergunte ao FixBot
    Comentar
  12. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 12, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 12, imagem 2 %32
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board.
    Pergunte ao FixBot
    Comentar
  13. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 13, imagem 1 %32
    • Remove the following three screws securing the right fan to the logic board:
    • One 4.4 mm T5 Torx screw
    • One 3.9 mm T5 Wide Head Torx screw
    • One 5.0 mm T5 Torx screw with 2 mm collar
    Pergunte ao FixBot
    Comentar
  14. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 14, imagem 1 %32
    • Lift and remove the right fan out from the MacBook Pro.
    • When reinstalling the fan, it's easiest connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
    Pergunte ao FixBot
    Comentar
  15. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Left Fan: passo 15, imagem 1 %32
    • Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
    Pergunte ao FixBot
    Comentar
  16. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 16, imagem 1 %32
    • Remove the following three screws securing the left fan to the logic board:
    • One 4.4 mm T5 Torx screw with 2 mm collar
    • When reinstalling the fan and its screws, don't fully torque the screws until you've first installed all of them loosely, so that the fan can move a little and position itself properly as you insert the screws into their threaded standoffs.
    Pergunte ao FixBot
    Comentar
  17. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 17, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 17, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 17, imagem 3 %32
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board. If necessary, use an iOpener or hair dryer to heat the cable in order to soften the adhesive and make it easier to remove.
    • Lift the left fan out of the device.
    • When reinstalling the fan, it's easier to connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
    Pergunte ao FixBot
    Comentar
  18. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, SSD: passo 18, imagem 1 %32
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
    Pergunte ao FixBot
    Comentar
  19. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 19, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 19, imagem 2 %32
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  20. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, I/O Board: passo 20, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, I/O Board: passo 20, imagem 2 %32
    • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
    • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    Pergunte ao FixBot
    Comentar
  21. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 21, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 21, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 21, imagem 3 %32
    • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
    • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
    • Carefully lift the I/O board and remove it from the lower case.
    Pergunte ao FixBot
    Comentar
  22. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Logic Board Assembly: passo 22, imagem 1 %32
    • Use the flat end of a spudger to pry the headphone jack connector up from its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  23. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 23, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 23, imagem 2 %32
    • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
    • Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
    • Be sure to pry on the cable head, and not on the socket itself. Prying on the socket may cause it to separate from the logic board.
    Pergunte ao FixBot
    Comentar
  24. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 24, imagem 1 %32
    • Peel back any tape covering the keyboard ribbon cable connector.
    Pergunte ao FixBot
    Comentar
  25. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 25, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 25, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 25, imagem 3 %32
    • Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pry only under the hinged retaining flap, not the socket itself, or you may break it off the board.
    • Use the flat end of a spudger to gently back the keyboard ribbon cable out of its socket by pushing first at one side, then the other.
    Pergunte ao FixBot
    Comentar
  26. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 26, imagem 1 %32
    • Use the flat end of a spudger to pry the trackpad ribbon cable connector up from its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  27. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 27, imagem 1 %32
    • Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  28. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 28, imagem 1 %32
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Pull the microphone ribbon cable out of its socket.
    Pergunte ao FixBot
    Comentar
  29. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 29, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 29, imagem 2 %32
    • Use the tip of a spudger to pry the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    Pergunte ao FixBot
    Comentar
  30. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 30, imagem 1 %32
    • Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near to the MagSafe 2 connector.
    Pergunte ao FixBot
    Comentar
  31. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 31, imagem 1 %32
    • Remove the following six screws securing the logic board to to the upper case:
    • One 2.6 mm T5 Torx screw
    • Two 5.8 mm T5 Torx screws
    • One 3.8 mm T5 Torx screw
    • One 5.2 mm Raised Head T5 Torx screw
    • One 3.5 mm Silver T5 Torx screw
    Pergunte ao FixBot
    Comentar
  32. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 32, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 32, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 32, imagem 3 %32
    • Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
    • Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
    • When reinstalling the logic board, check the cables at the marked locations to make sure they don't get pinned underneath the logic board.
    • Clockwise from top: keyboard, trackpad, battery, right speaker, keyboard backlight, display, microphone, headphone jack, left speaker.
    Pergunte ao FixBot
    Comentar
  33. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 33, imagem 1 %32
    • Remove the logic board assembly from the MacBook Pro.
    Pergunte ao FixBot
    Comentar
  34. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Heat Sink: passo 34, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Heat Sink: passo 34, imagem 2 %32
    • Remove the following eight screws securing the heat sink to the logic board:
    • Two 2.4 mm T5 screws
    • Six 3.4 mm T5 screws
    • Grip both ends of the heat sink and lift it up from the logic board.
    • When installing the new heat sink, do not forget to replace the thermal paste underneath the heat sink.
    Pergunte ao FixBot
    Comentar
  35. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Logic Board: passo 35, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement, Logic Board: passo 35, imagem 2 %32
    • Use the tip of a spudger to flip up the metal retaining flap on the HDMI data transfer cable.
    • Gently pull the HDMI data transfer cable straight out of its socket on the logic board.
    Pergunte ao FixBot
    Comentar
  36. MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement: passo 36, imagem 1 %32
    • Logic board remains.
    Pergunte ao FixBot
    Comentar
Conclusão
92 outras pessoas executaram este guia.
Brett Hartt
Membro desde: 04/12/10
132.245 Reputação
Autoria de 144 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.230 guias
4Comentários do guia
Seriously &&^& these apple screws glued with the power of a thousand suns litterally ruined 4 of the case screws getting the back plate off.
icemac - Responder Compartilhar
Perfect Guide. I'm impressed how easy it was to replace my logic board. It was my first Guide. You guys can change it to level 1, very easy, as long as the person does it without haste and with a light hand.
samoneda - Responder Compartilhar
Thank you for the time and energy making this high quality guide. I used it to extract the logic board allowing me to to clean off some corrosion from liquid exposure. This made the process pretty painless. Discovered the battery was swollen as well so ordered a replacement.
jdv - Responder Compartilhar
Considering how tedious and intimidating this job was, I couldn't dare re-soldering the gpu core if it weren’t for your guide. Thank you!
M S - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 30
Últimos 30 dias: 117
Ao todo: 121,718
