Ir para o conteúdo principal
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
75 Perguntas Visualizar todos
How to unbend aluminum from on screen corner?
I dropped my laptop and the corner of the metal frame bent into the laptop and is slowly pulling the laptop apart.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Can you post some pics so we can see the area and the where the system is not lining up. Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
2 respostas
You have to change the chassis. There isn’t really any other way
Esta resposta foi útil?
Pontuação 0
I just did this to my xps 13. The hinge could not open all the way. All I needed to fix it was to open the laptop slightly, wedge a smooth flathead screwdriver between the two metal covers (top/bottom) near where they contact and gently pry against the bent section to unbend it. The metal is VERY soft and did not take much effort. I used my forearm to push against the hinge to support it while I did this and there was no damage to the hinge.
Pontuação 0
Adicionar a sua resposta
Kennedy Cyprain-Chiaha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 677
