How to unbend aluminum from on screen corner?
I dropped my laptop and the corner of the metal frame bent into the laptop and is slowly pulling the laptop apart.
Esta é uma boa pergunta?
You have to change the chassis. There isn’t really any other way
Esta resposta foi útil?
I just did this to my xps 13. The hinge could not open all the way. All I needed to fix it was to open the laptop slightly, wedge a smooth flathead screwdriver between the two metal covers (top/bottom) near where they contact and gently pry against the bent section to unbend it. The metal is VERY soft and did not take much effort. I used my forearm to push against the hinge to support it while I did this and there was no damage to the hinge.
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 668
Can you post some pics so we can see the area and the where the system is not lining up. Adicionar imagens a uma pergunta já existente
por Dan
