Ir para o conteúdo principal
"O menor laptop de 15,6 polegadas do mundo traz um desempenho potente e uma impressionante tela InfinityEdge no laptop XPS mais poderoso da Dell."
Display hinge broke from base
Hi,
My laptop hit the floor and the post that the laptop base hex screw attaches to snapped off. Not a problem, however the laptop keeps separating every time I close the lid and I have to push the top and bottom together to put the laptop to sleep. It’s now causing more internal damage and when I open it up, the clip has snapped off the laptop base as well as the screw hole to the base is also cracked in half. I’ve attached pics but wanted to know the hinge was attached to that I need to replace, as well as the hinge itself. This is on the same side as the power button. Any info would be very much appreciated. And not sure if the pictures uploaded or not but have those too.
Thanks!
Update (04/09/2019)
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 4
3 comentários
Hi,
I have a XPS 15 9550 with a broken hinge. I tried to remove the antenna cover but it is really hard and I am unable to slide it. how can I remove the cover so I can access the hinges?
Thanks for your help.
Venkat
por Compartilhar
I bought a new chassis from eBay and swapped it all over.
I tried using liquid metal glue but it didn't hold so just bought a replacement chassis for £40
por Compartilhar
Replacement chasis? From where? Link please.
por Compartilhar
Adicionar um comentário
4 respostas
Solução escolhida
Hi @frankralfano ,
You need to replace the palmrest assembly.
Here’s a link to the service manual for a Dell XPS 15 9550 laptop taken from this webpage
Scroll to p.87 to view the necessary pre-requisite steps and then the procedure to remove/replace the palmrest assembly.
Replacements are available online. Just search for Dell XPS 15 9550 palmrest assembly to get results for suppliers of the part.
Esta resposta foi útil?
Pontuação 3
4 comentários:
Amazing, thank you so much! Lots of steps, wish me luck!
por Compartilhar
@jayeff , any suggestions on sourcing the palm rest assembly and not paying Dell $230 for it? I can't seem to find it anywhere on line. Part no is 05dy4c. Kills me to spend all of that money because of a broken post! Thanks again for your help.
por Compartilhar
Hi @frankralfano ,
Search online using the "part number only" in the search box of your browser. Apologies if you've done this already
Here's one that may be cheaper if the shipping doesn't raise the price too much.
por Compartilhar
Thanks @jayeff, I will take a look. Really appreciate all of your insights!
por Compartilhar
Have you resolved this yet..? It's what refer to as a “Design Flaw” by Dell.. I've had to engineer a solution for this problem, as I have seen multiple XPS Models with this very same thing happening.. Note: this is on the opposite side of the WLAN Connector, but I would probably handle it the same way… Cheers
Imagem
Imagem
Imagem
Imagem
Pontuação 1
2 comentários:
Hi Ruben, I really like your solution looks absolutely solid. Can you tell me which and which size screws and bolts you used for this fix please? Did you use any glue as well? Thanks
por Compartilhar
I know this is much later than your posting date, regarding screws and bolts, however maybe someone else viewing this post can be assisted by the answer to your question.
Screws are regular laptop Phillips Head - 2.5mm/3mm/3.5mm sizes (referring to width of course). Because I have thousands of these available in a shop environment, I simply searched for and found the longest screws available (1" to 1.5" length).
For the "bolts" parts of the answer, these are not bolts, but rather the Collettes (screw receptacles encased in plastic, gold or bronze colored) that broke off, and were originally fastened to the factory screws (look at the 4th image and zoom in).
If you don't have 100's or 1000's of Laptop screws around, as I conveniently do, I've seen eBay and Amazon sellers offering multi-packs of these type screws that one can acquire in 2-3 days after shipping, maybe sooner depending upon your locale..
This process I've now had to perform on more than just Dells, but HP's, Acers, Sony, Lenovo, etc.. Works great
por Compartilhar
because it’s a newer model, you may be able to check your warranty. also, because it’s a big hinge, you may need to open it up to re-attach it.
Pontuação 0
5 comentários:
Unfortunately it's been out of warranty for over a year. The hinge has broken from whatever it was attached to underneath the keyboard area. Looks like it was also glued down for extra support.
por Compartilhar
Oh. Since the XPS seiries os newer, I thought you might have your warranty.
por Compartilhar
Any thoughts on how to re-attach the hinge piece to the palm rest? The hinge plate is glued down and my left one, same side as the power connector, just de-laminated from the body underneath it. Is there a particular glue I could just re-glue it? Thanks
por Compartilhar
Hi @ Bill Layton,
I would try using something like this - example only and check how that goes.
It's a bit tricky with plastics as not all glues etc will adhere properly and some may even seem to melt them.
Good luck.
por Compartilhar
Glue won't do the trick, as far as re-attaching display hinges to the laptop base/palmrest assembly. Drill some holes, increase the durability beyond that of the original manufacturer's design (which is quite weak in many cases).
Look at the post where I'm referring to this as a "Hands Down DESIGN FLAW" by many manufacturers..
por Compartilhar
I own a Dell XPS 15 too. Due to a swollen battery (If you, like me, never heard about that, Google it) the left hinge was torn loose. I really needed the laptop, so ordering a and receiving a replacement palmrest and swapping everything was probematic. Also my eyes are getting week.
I bought a product called Quiksteel Steel Repair. I did some tests. It appeared strong enough and viscosity was OK. Little problem: Gluing has to be done within 4 minutes.
Important:
1. Roughen up the surfaces. I used a Dremel and a little mill and a rotating steel brush.
2. Degrease both surfaces well.
3. I disassembled the hinge, and glued the non-screen half. Placement has to be done very precisely. Mine was about 0,1 mm off, which made it a bit hard to assemble.
It's been a week now. Opening and closing goes smoothly. And the glue holds.
Pontuação 0
Adicionar a sua resposta
Frank Alfano será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 43
Ao todo: 12,185
