Ir para o conteúdo principal
Um Chromebook construído para suportar quedas, derramamentos de líquidos e impactos repentinos, projetado para a sala de aula e para quem passa muito tempo na estrada.
How does this panel come out?
[image removed]
This panel has a clip that won't come loose.
Edit: The rear panel has no clip, I was mistaken. There was nothing to remove.
[image removed]
I'm trying to get the hard drive out because I lost the charger and I have something to turn in tomorrow… anyone know how to get it out?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
what is the exact model number?
por
Because this is a Chromebook then all your work will be in Google Drive, so I think it might be easier to access it from another device. Just sign-in with your gmail address and all your work should be available.
por
Adicionar um comentário
1 resposta
Solução escolhida
Minater 247  Lenovo 11e the 20gf version does not have a hard drive. It has a eMMC (embedded Multi Media Card ) which is soldered to the motherboard. Nothing you can remove to get to your files. you will need to get a proper charger.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Minater 247 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 661
