Ir para o conteúdo principal
Dell Inspiron 15-3531 laptop with an Intel processor and a non-touch display.
14 Perguntas Visualizar todos
How to replace my thermal compound?
I’ve been searching for a way to access the CPU and GPU to replace the thermal compound on my laptop, but I haven’t seen anything that shows how, even on here. Does anyone know how to do this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi @kokohaishere ,
Here’s a link to the service manual for your laptop, taken from this webpage
Scroll to p.49 to view the necessary pre-requisite steps and then the procedure to remove / replace the heat sink assembly.
Once that is removed you can clean off and renew the thermal paste on the CPU/GPU etc.
You can also clean the fan at the same time ;-)
Esta resposta foi útil?
Pontuação 3
Here’s the guide for using Thermal Paste:
How to Apply Thermal Paste
Pontuação 3
Adicionar a sua resposta
Jayden Fox será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Ao todo: 1,842
