Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
iPhone 7 rear camera and flash not working
my iPhone 7 hard dropped from running bike ,
then after i got below issues
1) wont turn on ( Power IC replaced - Working fine)
2) audio prblem ( Audio IC replaced- only headphones not working charging works fine)
3) screen totally damaged ( new screen replaced)
4) Rear camera and flash not working ( after replaced U2501 ic also not working & also checked with another camera not works ) showing only black screen
i fixed all issues except rear camera , even after replaced U2501 ( CAMERA IC ) Problem was not fixed front camera working fine
kindly suggest me best solution to get my camera back to works again
Thank you
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Could be main board damage (smc was knocked off by drop or something along those lines) or the connector on the main board was damaged or if you're frame is bent or damaged it could be shorting out.
por
I’m guessing it’s CPU Issue
And compute benchmark score value is zero
por
Well it's probably main board not CPU. If it was CPU the odds of it booting is so low. Probably time for a new phone.
por
You are right but I spent more than $200 for this minor repairs
That’s the reason I can’t go for another phone
If I got solution this issue will fix it nd sold
Kindly tell if any jumper option to get fixed this issue
por
Adicionar um comentário
1 resposta
Solução escolhida
There are several power rails that power the Rear Camera, U2501 being only one of them. Check to insure that U2501 is properly powered by VDD_BOOST and then check the other rails in the image below.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Any jumper solution can work on that
Like remove U2501 IC and put jumper between A1 & A2 will work?
por
"Jumper solutions" are not solutions. You need to invest some time to understand what U2501 is (hint...it's an LDO) and what it does (hint...it takes VDD_BOOST and regulates it down to 2.9V).
If you jumper the input and the output of U2501, what happens?
por
Okay, thank you
I had small clarification kindly mention in detail
Is this rear camera unit connected to A10 cpu
Because previously I reballed
por
Adicionar a sua resposta
feroz_khan77874 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 967
