Capacitor problem, choosing capacitor
Good Day!!!
The board is vr1 version of sega game gear. I can't find a 33uf, 0.47uf, 4.7uf, 22uf, 68uf capacitor can I use higher value? Thanks in advance!!
Esta é uma boa pergunta?
Good Day!!!
Hi @faustrepair ,
You cannot use higher values than what the circuit design requires. It will change the characteristics of how the circuit operates (if it still will operate that is) if you do.
The type and values of the capacitors were selected for a reason when the circuit was designed
Did you check on places such as this?
Also you’ll have to know a bit more that just the capacitance value. Such as working voltage, what type of capacitor, physical size etc.
Esta resposta foi útil?
This is hit or miss, 1206 smd . <1uf use 1uf smd, <10uf use the 10uf, <100uf use 1210 SMD 100 uf. Few to many years later on this👍🏼
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Ao todo: 631
1 comentário
por Rumble Pirate
