Ir para o conteúdo principal
Lançado em setembro de 2013, identificado pelo número de modelo T100T. Portátil 2 em 1 com processador Quad core Intel® Atom™ e 2 GB de RAM.
Not powering on after charge
My T100TA has been habing trouble turning on. I popped the lid, unplugged the battery and left it unplugged for a good 45 seconds to a minute. Put it back together and I plugged it in overnight and now its white (leads me to believe the battery is ok). The white power LED still flashes 5 times even though,from what ive read, Ive performed a hardware reset. I will detail what Ive tried.
# Holding the power button down until white led flashes 5 times (camera side led turns on, no other response from device than that)
  1. Holding power button for 10 seconds (similar to 1. but after the 10 second mark the camera led turns off)
  2. Holding down “Windows Button" and power button simultaneously for 15 and 30 seconds (same result as 2. Tried holding them as if normal power on[2 or 3 seconds])
  3. Holding the volume up/down button and power button simultaneously (Same result as 1. Tried it for 15-30 seconds but results in the same reaction as 2.)
  4. Holding power button for over a minute (Same result as 2.)
Also tried all the methods listed above with the power connector plugged in. I also tried them with the battery unplugged before I charged it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Bad power adapter, battery or screen could be the reasons why the device will not turn on.
Check out how to resolve these situations: Asus Transformer T100 Troubleshooting
In case any further problem, you’d better back up your computer regularly.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I've checked the specifications of the micro usb cable compatibility (its not a 'charge only' cable) and the power adapters rating (5v 2amp) so that should be good.
Im not sure how else to test if the battery is ok other than seeing if a orange/red led is present after charging it overnight.
It could be the screen but I highly doubt it since its been stored safely and there have been no real issues with it prior.
por
You may just troubleshoot carefully by yourself, or ask some experts to do tests. Wish you good luck!
por
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 16
Ao todo: 642
