Ir para o conteúdo principal
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Volume switch does not work
Before fixing the monitor screen with double-sided tape, the volume switch works, but if it is fixed with double-sided tape it will stop functioning. Could I ask the reason.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You’ll need to verify that the Volume Button flex is properly connected and secured and that the flex is not damaged in any way. Check out this guide, specifically Steps 36-40. The application of the double sided adhesive may be exacerbating a flex issue.
Esta resposta foi útil?
Pontuação 5
4 comentários:
Although there are neither breakage of parts nor looseness of screws.
por
You would be surprised that these parts fail from just dropping the iPad it happens. You'll need to get that volume flex assembly replaced.
por
Thank you for helpful information. By the way, why does it happen just by exchanging panels? Specifically, which part?
por
Possibly the volume flex got damaged when cleaning the iPad housing of the old adhesive. It is the part that Minho linked as shown in the guide above.
I've done it once, when not being careful near the volume area when cleaning. It intermittently worked one of the buttons because they got damaged.
por
Adicionar a sua resposta
Shigeaki Niikura será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 110
