Ir para o conteúdo principal
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Perguntas Visualizar todos
Power on, No Chime and No Video.
I was given a Mac Pro 8x with an apparently bad power supply. I have replaced the power supply with a working one purchased on Ebay. Now, when I power it on, the LED over the power button comes on and stays on. All of the fans spin up, but do not seem to be max RPM. I see the memory boards light up then go off. I hear the HDs spin up.
Here is what I don’t hear/see. There is no Mac Chime, video never comes on. When I depress the DIAG_LED button I see TRICKLE, GPU_PRESENT, PWR_ON but I never see EFI light up.
Here is what I have done to troubleshoot. I have tried 3 different video cards in all the available slots. The original GeForce 7300 GT, GeForce GTS 450 and an Asus EAH3450.
I have replaced the onboard battery CR2032
I have removed all HDs, swapped through all the memory modules and in every combination from 1 GB to 4 GB.
I still get nothing. I have read this solution: Powers On but No Video
And still nothing.
Any help that can be provided would be greatly appreciated.
I went ahead and removed the CPUs and they are in a state I have never seen before. This is the First MacPro I have disassembled and I have never seen CPUs/Heatsinks with this sort of residue on them. I have tried to clean them off but with no real effect.
Is this normal?
Peter Barton
Esta é uma boa pergunta?
Pontuação 1
3 comentários
@oldturkey03 do you think the issue is a faulty power supply? Simlar issue to: Powers On but No Video
por
First we really need to know your exact machine. Please enter your serial number here and let us know your results.
https://everymac.com/ultimate-mac-lookup...
por
Adicionar um comentário
1 resposta
Solução escolhida
I found a replacement CPU and that did the trick. I was able to get to the Apple Load screen!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Peter Barton será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 248
