Ir para o conteúdo principal
Service and repair information for the Huawei Mate 8, which was released in November 2015. It runs Android OS, v6.0 and sports a 6.0-inch display. In addition to a 16MP primary camera and an 8MP secondary camera, the Huawei Mate 8 also has a non-removable Li-Po 4000 mAh battery.
15 Perguntas Visualizar todos
Does changing the battery also require us to change the screen?
I've been having battey charge drop problems. When I go to the Huawei service center they tell me that battery change will also require a screen change. (Without even checking my phone). They say that the battery comes with the screen. My screen is in perfect condition. Is it true that the battery change will also require a screen change?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
@slot1gamer @jayeff Thank you guys. It sounded silly to me as well when they said that the battery and screen both have to be replaced.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Hi @alieffendi ,
Looking at the Substituição da bateria para o Huawei Mate 8 guide, it is not necessary to remove or replace the display.
If you decide to replace the battery yourself, read the comments at the bottom of the guide for a tip that may be of some help.
Pontuação 3
2 comentários:
depending how you look at it, are you removing the screen or removing the back?? hmmmm
por
Hi @slot1gamer ,
Fair enough.
I've amended my answer.
Cheers
por
No they are being dumb..
The battery is stuck to the mid frame with some double sided tape, this is a job a day 1 tech can do.
Pontuação 1
Adicionar a sua resposta
Ali Effendi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 125
