Ir para o conteúdo principal
Modelo A1200 com processador Core 2 Duo de 2,16 ou 2,33 GHz
hard drive replacement manual
I have searched the manuals and cannot find one on the hard disk replacement of the EMC 2111 24" intel imac.
I understand that there is one but cannot find it.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Doesn't appear to be one on the site. But for what it's worth, here's a Macworld article by Kyle Wiens describing the process, though (along with links to other ifixit guides for similar models): http://www.macworld.com/article/145116/2...
The key quote: "The later G5 iMacs and first Intel models are tough: They have nasty retaining clips holding the front bezel in place. Removing the bezel requires a flat pry tool, such as a credit card or ID badge. You also need to completely remove the LCD display and lower EMI shield before you can access the drive. Rating: Difficult"
Esta resposta foi útil?
Pontuação 2
Someone woke this one up after 3years, I thought I might as well update the answer. The guide for the hard drive replacement can be found right here
Pontuação 1
Adicionar a sua resposta
David Randall será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 2,656
