Ir para o conteúdo principal
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
Fuse for cigar and console
Where is the correct fuse for cigar and middle console power outlet
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
I don’t know your vehicle but according to the owner manual for a 2000 Ford Mustang (you don’t state the year model) the fuse for the cigar is fuse #1 in the passenger compartment fuse panel. The fuse panel is located below and to the left of the steering wheel by the brake pedal.
The manual also shows that fuse #9 in the engine bay power distribution box is labelled as Auxiliary Power Point which may be worth checking out to see if this is the one for the console power outlet.
Here are some images taken from the manual to show the fuse locations and designation.
Imagem
cigar fuse
Imagem
Imagem
auxiliary power fuse
(click on images to enlarge for better viewing).
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 1
2 comentários:
2003 centennial edition 100 badges on mustang gt
por
@Joe A
For a 2003 Ford Mustang it should be the same fuses as shown above
por
Adicionar a sua resposta
samanthahutchins05 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 66
Ao todo: 7,216
