Ir para o conteúdo principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 Perguntas Visualizar todos
Headlight won’t turn on
The passenger side headlight on my 2003 Nissan Altima won’t turn on. I changed the bulb twice, checked the fuse box under the hood and won’t turn on idk what’s wrong with it. Please help me
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
The following images are from the 2003 Altima Service manual (lighting system LT) showing how to check the low beam headlight circuit
(click on images to enlarge for better viewing)
The IPDM E/R means “intelligent power distribution module - engine room”.
If there is no power to the headlight connector and the ground check is OK and if the harness tests OK between the headlight connector and the IPDM E/R then there is a problem with the module and it needs to be replaced.
Here’s a link to the various sections in the manual which may be of some further help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
dowellblake será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 22
Duração total: 1,025
