Ir para o conteúdo principal
The HP Stream 13-c010nr is a Windows 8.1 PC designed to compete with the Chromebook released in November 2014. The HP Stream 13-c010nr is identified by its model number: K2L96UA#ABA .
3 Perguntas Visualizar todos
Can I remove the actual keyboard board itself?
The current keyboard is no longer recognized and i’ve tried checking the cords and nothing has worked. I have a replacement keyboard board but no frame with it. is there anything i can do about that? also the computer does not power on but it does charge, not sure if that has to do with the keyboard and the power button
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
The keyboard in the laptop is part of the top cover.
I’m not sure whether you can successfully separate the two to replace the keyboard, as I think that you may have to “break” the tabs that hold the keyboard onto the top cover.
Here’s a link to the service manual for your laptop, taken from this web page which may be of some help.
Scroll to p.29 onward to view the necessary pre-requisite steps and then the procedure to remove the keyboard /top cover.
Once you have access to it you may be able to determine if you can successfully replace just the keyboard only.
On p.36 it details how to remove the Power button board.
Once you have disconnected the board cable from the motherboard, use an Ohmmeter to test the button for continuity.
If the button is faulty, the part number is at the top of the page.
Search online using the part number (792777-001) only in the search box of your browser, to get results for suppliers of the part
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Noah Andrew será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 137
